- Joined
- Nov 2, 2021
- Messages
- 1,116
Buy the cheapies and replace often not worth the extra coin and load on your blower
A dirty filter does a better job than a clean one..... to a certain point.Buy the cheapies and replace often not worth the extra coin and load on your blower
I had two heating contractors tell me it's best to have good air flow and not use those highly restrictive, high merv filters( over 5 merv ). One technician believed my use of a high merv filter may have contributed to my heat exchanger cracking. I now use those glass woven rock catching filters and stay away from high merv filters.I just bought a 3M Filtrete Furnace Filter that has a Merv rating of 5 for dust and lint. Is it necessary to have a filter with a higher Merv rating in the winter since the air is cleaner.
That is what a lot of HVAC people say....Even the real cheap fiberglass ones...Just change every 30 days and you will be fine...Buy the cheapies and replace often not worth the extra coin and load on your blower
End dust spray works great also...If one has an older belt driven blower system that like old school low restriction fiberglass filters just spray dusting polish on the upstream side of the filter to add tackifiers.
This is so true. My RA inlet plenum is 40 X 60, so uses (2) 20 X 30 Merv 11’s …You need to be careful when switching to Marv rating filter since the vast majority of ducks are undersized. To do it safely you need to check the air flow and if needed adjust it.
Similar to the agreement we have with our long term HVAC company (2nd generation company) …I had two heating contractors tell me it's best to have good air flow and not use those highly restrictive, high merv filters( over 5 merv ). One technician believed my use of a high merv filter may have contributed to my heat exchanger cracking. I now use those glass woven rock catching filters and stay away from high merv filters.
They are great, until they get even slightly plugged. The 3M filters are terrible.Filtrete puts the pressure drops on the filters, I was surprised after reading that study and the 1900’s really are lower than the lower merv ones.
Not necessarily, as I described above sometimes the higher MERV filters offer less pressure drop… probably because they have far more pleats.
Answer = NoI just bought a 3M Filtrete Furnace Filter that has a Merv rating of 5 for dust and lint. Is it necessary to have a filter with a higher Merv rating in the winter since the air is cleaner.
Wow, I hate the K&N brand but they might have something here. Looks well made.No mention of the MERV rating...
