Originally Posted By: bugeye
Installed one on a 2013 Hyundai Sonata. The oil changes by the dealer for the previous owner left an oil and grit mess on the top of the plastic belly pan. Grrr. After using a Fumoto valve and a short tube, no more oil on the belly pan. No dealer changes for me, they are too sloppy. I drain hot into a empty 5 quart oil container. Easy to keep belly pan clean. I use a sleeve over the oil filter so nothing get on the pan as everything dripping in the sleeve go in the drain pan.
I do pretty much the same. What kind of sleeve do you use, where did you get it? I'm interested.
