Originally Posted By: aquariuscsm
Originally Posted By: sleddriver
Originally Posted By: Rat407
Food for thought but with today's technology one would thing we would be a lot farther along with fuel economy than we are.....Just seems odd that we are no farther along than we are when it comes to economy.
Surprising that only one guy mentioned the key ingredient: GAS.
Not only are gas formulations different (lead vs. no-lead), but today most burn gasohol! For every 10ga you buy, a gallon of it is ethanol.
If you want to see your fuel economy improve, along with performance, fill up with 100% gas.
Whatever happened to the gasahol craze in the 70s? You'd constantly hear about it and then one day it disappeared.
Probably didn't make any sense given that gasoline was cheap. However, there was the benefit of "octane giveaway". It would boost the octane rating 2 or 3 points, but then they used a base fuel that met the requirements. So if you had 87 octane on the pump, it might have been closer to 90 if ethanol was added.
What ended up happening in the 90s was that oxygenates were more or less mandated for emissions reasons, and MTBE turned out to be a disaster. I think that's when E10 became far more common, once MTBE was pulled.
