Wow, side question. Did the insurance companies go after her personal finances or was her policy just maxed out?My aunt hit fog and was the first to smack a stopped car in a 100 car pileup , she was held liable, the cost was a fraction of the bridge mentioned and 20 years later is still getting legal updates.
I read that there are military 4 sea lift ships or something stuck in the harbor.The military thinks it can clear the main channel in a week if all resources would be deployed, but that is unlikely and the investigation will likely hold things up weeks by itself
At 8 knots? I doubt it.Do you think it's possible that dropping the anchor caused the ship to steer towards the pier? Supposedly when power came back online for a moment before the collision that's when the anchor dropped. I'd assume there is a manual override for this but that might be require a lot of manpower and time to do so?
What side was the anchor on, IDK, but maybe it caused more hard than good.
Edit: looks like the anchor was on the port side AFAIKT:
Surprising to see the ship is floating evenly despite having a bridge on top of it including a massive chunk of concrete on the bow.
View attachment 210829View attachment 210830
GravityI'd assume there is a manual override for this
Tells you how large and heavy the ship is relative to the weight of parts of this bridge.Surprising to see the ship is floating evenly despite having a bridge on top of it including a massive chunk of concrete on the bow.
The ship was staffed with Indians, presumably because the boat owners want to pay as little as possible for wages. What makes you think that they are going to maintain a potential backup generator? Clearly, they didn't maintain their engines because that costs money too, and would require competent employees that would cost more.Sure would have been nice to have the back up generator/turbine up and running in the event
you need it for back up power/propulsion.
It is resting on the bottom of the channel, hopefully no damage to the hull. There’s not usually a lot of space under a fully loaded ship in many ports.Surprising to see the ship is floating evenly despite having a bridge on top of it including a massive chunk of concrete on the bow.
The Chesapeake Bay itself is not deep like a Great Lake. Ships have to be careful the whole trip from the ocean to stay in the dredged channels. One got stuck in the middle of the Bay a year or two ago.There’s not usually a lot of space under a fully loaded ship
I'm sure there was a risk vs. cost scenario and again it based on the fact that it would impede traffic in the harbor which now is a moot point. The cost to rebuild was also a factor. Not easy to retrofit in certain scenarios, I'm am sure.Every bridge in San Francisco Bay and San Pablo Bay has fenders to protect their supports. This includes bridges that are over 85 years old. A container ship went head on into a support of the Oakland-San Francisco Bay Bridge in 2007. It didn't cause any damage to the bridge, but the ship did leak fuel into the bay.
I can't understand why wouldn't have it on standby in the harbor. Once out at sea sure switch it off. Sounds like a prudent plan to me.I suspect that in the future, tugs through the bridge might be required for large ships....though it's debatable if they
could do anything to change ship's course within 1-2 minutes. Those on the ship manning key control stations may need to be reinforced....esp. emergency controls where hydraulics, elec power or other systems are lost.
you need it for back up power/propulsion. US Navy ships have twin propulsion engines and twin turbine generators.
If these large merchant ships have them, why not test or run them during initial underway so they are ready and warmed up?
I'm sure it costs the owner's extra money to do that. But, it also costs a lot less than loss of life, loss of a bridge, and loss of part
of the region's economy. What good is a back up or second engine or generator when it's not ready when you absolutely need it?
It may not have been for that particular span, but I would certainly argue it could be for the Baltimore one based on space available, harbor floor, etc...Adding fenders isn’t that hard a retrofit. Here’s the Richmond-San Rafael Bridge (the image is from a government website and in the public domain). Over the years they reinforced the tower supports with additional concrete, and also out in fenders. There’s not quite the same traffic as the Oakland-San Francisco Bay Bridge, but there is a tanker dock, and Mare Island Naval Shipyard was previously operating. There’s other shipping traffic there including for a sugar factory. I don’t think they get mega sized container ships though. A cantilever bridge might be able to stay up if one of the smaller supports is destroyed. But the main supports are protected with lots of concrete and big fenders.
I lot of factors go into play especially if you need adequate clearance for the mega container ships and also want to stop them at the same time.
Not sure fenders would have been completely effective against that much mass.
It seems like they may have been steering to try and avoid a power line emplacement between the ship and the bridge and either over-corrected or weren't able to straighten out the rudders or adjust prop speed once they lost power again, going by drone footage. I don't think wind or current was a factor.Was the ship off course? It should have been aiming for the center of the bridge. When the power loss happened wouldn't it continue straight? Of course, I don't know the winds or currents, but if they knew they were that strong a tug would/should have been planned?
Bad fuel could take out the main and gensets if they pulled from the same tank. Just some questions.
When you're about to crash, aim at the least expensive thing that you see. It would have been better to hit the power line and have a chance to slow or stop before reaching the bridge.steering to try and avoid a power line emplacement
