Thanks for the info. I wonder if Nissan made some changes to their oil filter line up.. 15208-65F1A/B is also what I'm seeing on the Nissan Parts USA website for compatibility.Well, the Fram part number came from their site. 2023 Rogue w 1.5 ltr turbo. The external housing was approximately the same size. The Internal construction dictates element size. Please notice the different applications of bypass valves. Apples to apples the best I can tell! If you search the Nissan part number on the Fram site, FE6607 is the cross that comes up. I surely understand your comment regarding the size, but it is what it is.
Not sure, but I was thinking that the "A" series was the factory installed filter. The "B" replaces that according to the dealer where I purchased the car.Thanks for the info. I wonder if Nissan made some changes to their oil filter line up.. 15208-65F1A/B is also what I'm seeing on the Nissan Parts USA website for compatibility.
I had issues with my 2013 Rogue and torn oil filters, so maybe this is the solution with a more robust design?
If the Nissan filter is longer, then Fram should have specified the FE7317 which is the same as the FE6607, only longer (ie, the "oversized" option). What does Fram show for the Ultra for you Nissan ... also the 6607 version?Apples to apples the best I can tell! If you search the Nissan part number on the Fram site, FE6607 is the cross that comes up.
All Fram part numbers were 6607If the Nissan filter is longer, then Fram should have specified the FE7317 which is the same as the FE6607, only longer (ie, the "oversized" option). What does Fram show for the Ultra for you Nissan ... also the 6607 version?
