Fram 3614 need shorter filter
North Carolina
wix 51394 3614 is 3.34 inches high thread is 3/4-16 bypass 12psi wix 51394 is 2.97 inches high thread 3/4-16 bypass 8-11psi Donaldson 502024 is 2.56 inches high, thread 3/4-16 bypass 11-16psi NO ADBV
USA
Originally Posted by MrMoody
Originally Posted by slacktide_bitog
4967
If it will fit & seal at the base: the diameter and gasket are smaller.
Oh. I thought the 4386 and 4967 had the same gasket diameter as the 3614 I thought people on here installed 3614's and even 3600's on cars that spec 4386/4967
USA
Check your gasket landing on the vehicle to make sure you don't make a messy / costly mistake. - PH4967 is 2.9" tall with gasket 2.21"/2.48" ID/OD, 12psi relief valve, 2.66" OD, 3/4-16 thread - PH3614 is 3.3" tall with gasket 2.45"/2.76" ID/OD, 12psi relief valve, 3.01" OD, 3.4-16 thread (Source: FRAM.com website)
