Fram 3614 need shorter filter
wix 51394
3614 is 3.34 inches high thread is 3/4-16 bypass 12psi
wix 51394 is 2.97 inches high thread 3/4-16 bypass 8-11psi
Donaldson 502024 is 2.56 inches high, thread 3/4-16 bypass 11-16psi NO ADBV
Originally Posted by slacktide_bitog
4967
If it will fit & seal at the base: the diameter and gasket are smaller.
4967
Oh.
I thought the 4386 and 4967 had the same gasket diameter as the 3614
I thought people on here installed 3614's and even 3600's on cars that spec 4386/4967
It's not a lot of difference. Many applications will fit and seal, it depends on the mount. I know they work on our Toyota.
8172, 8170 I think that's about it.
What he said 👆ðŸ»ðŸ‘†ðŸ»ðŸ‘†ðŸ»
PH8172 -smaller
https://www.fram.com/parts-search/P...CmUQBoQAUASAHAIwDsATNogDbVY10P0K3OsMC6QA
PH8170 smallest
https://www.fram.com/parts-search/P...CmUQBoQAUASAHAIwDsADNogDbVY10P0K3OsMC6QA
Check your gasket landing on the vehicle to make sure you don't make a messy / costly mistake.
- PH4967 is 2.9" tall with gasket 2.21"/2.48" ID/OD, 12psi relief valve, 2.66" OD, 3/4-16 thread
- PH3614 is 3.3" tall with gasket 2.45"/2.76" ID/OD, 12psi relief valve, 3.01" OD, 3.4-16 thread
(Source: FRAM.com website)
Here is the PH4967 gasket laid on top of the PH3614 per the dimensions on FRAM's site. There's only 0.03" of overlap.
[Linked Image]
