Hello, Just looking for a good fuel additive for my 1120 diesel.. what’s some good ones you guys would recommend.. thankyou!!
The cleaning part isn't an issue if you just keep what you need in there, change the fuel filter regularly, and make sure the system doesn't become infected by making sure water doesn't get in so that means changing the fuel cap or just the seal if it looks flattened. The lubrication part isn't as big of a deal with modern diesel formulations but a bit of cf-2 sae 30 or 2 stroke mix works well. Many other forums say to mix a bit of either in. Some say one is better than the other. I think I'd use 2 stroke instead since it burns cleaner for sure.Yes just want to take care of it the best I can.. I don’t use it in the winter. It stays in a heated garage. Just extra lubrication and cleaning.
