There are a bunch ow AW compounds that can be put in oil ZZDP was cheap and easy, so it got put in older oils. Modern oils have to be backward compatible and they can't have higher Zn & Ph levels, so they go to the more expensive AW compounds.
Chevron is advertising 50% less wear from the new CK4 HDEO's and they would not make those big public proclamations if they did not have lab results and over the road test results to back it up. To many big fleet operators with lawyers would be looking to skin their behinds if it were not at least partially true ...
I would not worry terribly about modern oils. I do worry about viscosity and some about oxidation. But wear, no.
Biggest flat tappet I have built is a .630 lift BBC with more than 400# over the nose. Crane cam, Howards lifters, Howards springs, thrift store push rods, Comp stainless roller rockers in 781 heads. Peaked at 6,300 and revved to 6,500 for shift purposes. Ran two years on the street on Delo 400 before it got sold. No issues.
What are we trying to find out here ...
