- Joined
- Nov 28, 2021
- Messages
- 136
A fingerprint or face scanner isn't going to stop my tow truck from being able to steel your car. It is a cute idea though. Nice try.
No system is perfect, but why totally dismiss them just because someone out there can defeat it? Sometimes deterrence is enough. Security improvements are not just nothing to perfection. They are incremental improvements that help reduce the occurrence of thefts. Just saying someone can defeat them does not invalidate their improvement and effectiveness as security devices.that only works if you cant bypass the lock electronically. which they can now do on vehicles.
If various movies are to be believed, the thief will cut off your finger to steal your vehicle.You can’t transponder copy a fingerprint
Friends who travel a lot mentioned this except it was engagement ring thieves in [fill in your favorite place to malign here].the thief will cut off your finger to steal your vehicle.
what I'm saying is that is no better than a key, it can be stolen regardless. so why complicate the car anymore.No system is perfect, but why totally dismiss them just because someone out there can defeat it? Sometimes deterrence is enough. Security improvements are not just nothing to perfection. They are incremental improvements that help reduce the occurrence of thefts. Just saying someone can defeat them does not invalidate their improvement and effectiveness as security devices.
Again,If various movies are to be believed, the thief will cut off your finger to steal your vehicle.
But how do you know which finger they used? You gonna cut off all ten and try each one until it starts?
Yikes! Another vote for my Saferingz silicone rings.Friends who travel a lot mentioned this except it was engagement ring thieves in [fill in your favorite place to malign here].
Again, I don't want to be a beta tester for the automobile toy industry.
Every software can be circumvented or broken. Yes, every one, because human coders are predictable, and not perfect.Say in the future, car companies start implementing a finger scanner like an iPhone to protect against theft.
So a push button start with finger scanner. You’d have to register every driver. Assuming the software was robust and not easily circumvented, would you be interested in such a feature?
But is a physical key easier to defeat than a finger scanner? I think it is. But I guess the issue with finger scanners is, if you have some software hack tool you can plug into the obd2 port, you can hack all cars using that software. A physical key may be better.Every software can be circumvented or broken. Yes, every one, because human coders are predictable, and not perfect.
they don't even need to hook into the obd port, can be done by the connection to the headlight from under the car or behind the bumper. very quick and very easy.But is a physical key easier to defeat than a finger scanner? I think it is. But I guess the issue with finger scanners is, if you have some software hack tool you can plug into the obd2 port, you can hack all cars using that software. A physical key may be better.
But I still think with $$$, you could make a very robust finger scanner security program. Maybe like an online database.
Right but is that the fault of the finger scanner? I’m assuming more competent engineers than that.they don't even need to hook into the obd port, can be done by the connection to the headlight from under the car or behind the bumper. very quick and very easy.
I think a finger print reader would be much more difficult to defeat than you all are estimating. There’s a reason lots of high tech facilities use them for security.
My understanding is they have to clone your key fob first in order to do this.they don't even need to hook into the obd port, can be done by the connection to the headlight from under the car or behind the bumper. very quick and very easy.
No thanks, Big Brother.But is a physical key easier to defeat than a finger scanner? I think it is. But I guess the issue with finger scanners is, if you have some software hack tool you can plug into the obd2 port, you can hack all cars using that software. A physical key may be better.
I see you were a veteran… they already got your number bud. You were in the system the day you signed that contract.No thanks, Big Brother.
This will most likely be the solution.Why not use facial recognition for you to unlock the door and start the vehicle instead?
Yea I don't think anybody is going to go as far as Mission Impossible to steal a car with a fingerprint scanner.
