Originally Posted By: AVB
Originally Posted By: Iowegian
Originally Posted By: Trav
Originally Posted By: Olas
Pull yr injectors to check for leaks, then suspect rings.
No need for that just look at the fuel trims.
Fuel tim looks really good...after I replaced the MAF sensor a month or so ago.
Was the UOA done on the oil run with the old MAF sensor? You may have fixed your problem.
Yes it was. Fuel trim was running at about 6% to 9%. Now it hovers around 0.
But I don't think that caused the problem. Higher fuel trim doesn't mean "more" fuel. If the o2 sensor is accurate (replaced that a few months ago) then there is no access fuel in the chamber. There is however, a lean mixture occurring at acceleration at first before the o2 sensor detects the lean mixture and for the ecu to compensate by increasing the fuel trim.
Maybe I am missing something.
