I drained my radiator, then I accidentally let out all of the R-134a (refrigerant) from the condenser in front of the rad. I have to bring it to an AC shop to get it filled but I need to fill the rad back up first to drive it there. I know that I need to burp the radiator by squeezing the hose. Also, I learned that I am supposed to turn the ac heat on high in the front and rear to also get the air out. But I can't do this because I lost all of the rifgerant! What am I supposed to do? Is it safe to drive with some air in the coolant system because I cant use the HVAC to get the air out? Is it a must to do this AC method to bleed air out?
Thanks
Thanks
