If you have a sealed Snap-on ratchet and like taking it apart to clean and relube it, be careful about what you choose for a lubricant. I took two of my ratchets apart tonight and the seals almost jumped out at me they were so swollen. There is no way those seals are going back in there. I had fresh rebuild kits in both of those ratchets and those seals have been in contact with only one type of lube: Federal Mogul Sealed Power #55-400 engine assembly lube. It's a fantastic lube for ratchets, but if you have seals in your ratchets, I recommend sticking to the factory recommended lube. In the case of Snap-on, their factory installed lube is Super-Lube #21030 and their ratchet rebuild kits come with that lube. It's not the best ratchet lube in the world, but at least it won't swell the seals.
If you're the guy who never takes his ratchet apart and lets the dealer service it, disregard all of the above.
