Excess glue
Bought a Wix filter for the wife's Envoy. Never noticed this much glue on the center tube before. Should I be concerned?
we just need to stop buying M+H products until they fix these issues.
In the opinion of filter dissectors, do beads of glue break away in these configurations?
Excess glue can certainly break away, unfortunately. I did a C&P here on BITOG showing one example, and I've seen other examples in the oil filter section.
^^^ That looks like a well formed glue job. Many filters I've inspected have a glue seam similar to that around the base of the center tube. Here's a MicroGard Select with a similar glue job - but with even a wider glue seam. That glue should not move at all, it's stuck very well. I've never seen any filter lose glue from that area over the OCI use of a filter.
I would send that back-any of that falls off=a disaster. Shouldn’t have made it out of the factory! Is that Mann & Hummel? (as if I need to ask…)
What is this based on?
This isn't random loose glue splatter, dribble, excess.
I'm not defending M&H, but this simply is not a failure and you are actually wrong causing undo worry.
