Originally Posted By: madRiver
Originally Posted By: ARCOgraphite
MadR - Can you feel the alignment out - its usually VERY noticeable.
You can get the toe pretty close if you have a flat driveway with string. But seeing you went to a shop to get a tierod, I guess you'd not be inclined to do a shade tree alignment.
Wonder if anything else was damaged/bent?
You may know the local mechanic(Scott Harlow) I am guessing he did a shade tree on it and put the sticker on it after some other work. He is extremely affordable and fair/honest to do that kind of repair for my work/life balance.
I only noticed the MDX drives a ton better with fixed tie rod, I was getting weird jerk driving at random times with apparently broken tie rod.
I know Scott.. He is my Subaru Insider. He's down off RT27 near Exeter.
Good mechanic. An yes he does not have a Rack. But most guys around there don't know how to use it or don't care and many are WAY WAY out of cal. I recall Exater Subaru didn't have a rack either when he was Service Mgr there in the 90's.
900 for tires! Yikes! Id be doing discount tire direct and then going to the Honda dealer for an install. That was always my cheapest option.
Good luck and nice truck ( I hear).
