Originally Posted by Driz
Try to keep the carb empty when it sits long term. That ethanol draws up enough water to corrode the inside of it. Once you tear a few of these small carbs down it's pretty obvious what that alcohol does inside the passages when it sits a long time. My snowblower when I got it had the bowl corroded in the very bottom. One spot even pinholed right through. That's the ethanol's magic legacy.
I run my Craftsman lawnmower's Honda engine out of fuel on the last use of the year. Is the carb completely empty at that point?
