Do you replace oil drain plug washer...
Carlostrece
$100 Site Donor 2025
PNW
...at each oil change? I never heard the advice to replace washer when I was young. It wasn't until I was older that I read that advice. I don't think my oil drain plug washer has ever been replaced on any car I've ever owned. It's never been a problem for me.
Why does that advice exist? Is it really a good idea?
Do mechanics replace the flat washer at each oil change?
If so, why? Do flat washers wear out?
Is it an ordinary flat washer or some special type washer?
Crush type washers deform to effect a seal. Additionally, the deformation may work harden the (metal) washer which along with the initial deformation, may affect the washer's ability to seal again. Most of what I own use aluminum or copper crush washers and I generally replace them each time, but I have smoothed and re-annealed a few in a pinch. At ~$1 a seal tops, cannot see a reason to not replace them.
This is a classic BITOG topic!
Here’s a great 8 page discussion which I found very entertaining!
I expect it depends on how the pan and plug were designed to interface to make the seal. I was always told by the parts counter at Honda that their oil plug crush washers were designed to be a one-time use item. The attached image is a page from the '92-'95 Civic service manual - it indicates the washer is to be replaced.
In comparison, if a washer were not designed to crush (ie. made of a harder metal) it may not need to be replaced. Softer metal - like any gasket - will deform to match the imperfections of the plug and pan mating surfaces.
I have a stack of them in the maintenance drawer. If it's copper crush washer, I tend to do it each time but I'm not 100% consistent. If it's an aluminum type, I do it now and then.
I haven't had any leaks with my current methodology, I'm not going to sweat it.
While I have washers on hand I only inspect them on removal and flip them to the other side after cleaning and when installing it back.
I don't think those washers need to be crush washers, flat alum or copper ones work.
I never have until recently. After the last oil change on the Mercury, it started leaking.
I decided the best course of action was to replace the drain plug with the drain plug from the original engine. Good thing I kept that around.
Came here to say this. Usually one thread still running.
