The GMs with the built-in hard plastic (or is it rubber?) seal is the best design.On one vehicle I re use it but my gm's have it built into the plug so it's not needed.
They really are the best design, i still have the factory drain plugs on my old trucks too. It feels like a bn70 o ring, doesn't feel as hard as 90.The GMs with the built-in hard plastic (or is it rubber?) seal is the best design.
Or are you supposed to replace the plug periodically?On one vehicle I re use it but my gm's have it built into the plug so it's not needed.
Yea, because everyone prefers replacing the entire drain plug, when it starts leaking, instead of just a flat washer.The GMs with the built-in hard plastic (or is it rubber?) seal is the best design.
The Jiffy Lubes and their 300-ft/lbs installers probably are the only things that can make them leak. The seal probably deforms eventually.Yea, because everyone prefers replacing the entire drain plug, when it starts leaking, instead of just a flat washer.(That is sarcasm, in case you couldn't tell.)
I had a GM car a long time ago with over 150,000 miles on the original drain plug and it never leaked. You can replace the seal. Plug is under $3 at Rock Auto.Or are you supposed to replace the plug periodically?
I used to drive an Alero with the 3400 engine, which had a drain plug with a plastic washer, which could not be easily removed. While it held up good for many years, the plastic washer eventually cracked and leaked. I wasn't impressed.The Jiffy Lubes and their 300-ft/lbs installers probably are the only things that can make them leak. The seal probably deforms eventually.
Here are a couple hundred posts on the topic....at each oil change? I never heard the advice to replace washer when I was young. It wasn't until I was older that I read that advice. I don't think my oil drain plug washer has ever been replaced on any car I've ever owned. It's never been a problem for me.
Why does that advice exist? Is it really a good idea?
Do mechanics replace the flat washer at each oil change? If so, why? Do flat washers wear out?
Is it an ordinary flat washer or some special type washer?
So it's a special washer called a crush washer, not just an ordinary flat washer?Here are a couple hundred posts on the topic.
I have noted increased enthusiasm for changing oil drain crush washers at every oil change. I have never landed on a solid opinion here and wonder what is true. Are crush washers deformed, and forever changed after one crush? Is there any actual design that goes into crush washers? Is there a difference between the golden ones and the silver ones? If they are not to be reused, can we account for people who never change them and never have failures? On the same note, has anyone ever heard of a crush washer failure?
- TomYoung
- Forum: Mechanical/Maintenance Forum
Bottom line - if it is a crush washer, they deform, and your odds of a leak go up every time they’re re-used.
I don’t chance leaks over a 10 cent washer, but a lot of guys here will argue about saving that ten cents.
Owners manual makes no mention of that nor have i ever heard of needing to do that but on my 2021 it does mention a need to replace the ac desiccant every 7 years which I never knew was a maintenance item at least on anything not exotic. I know they go bad when exposed to the moisture in the air from the system being empty and letting it get inside but I was under the impression that as long as the system is well pressurized the moisture shouldn't ever make its way in but there's likely more to it than that.Or are you supposed to replace the plug periodically?
Have you read the Service Manuals for your cars, to see if they mention replacing the oil plug washer?Owners manual makes no mention of that nor have i ever heard of needing to do that but on my 2021 it does mention a need to replace the ac desiccant every 7 years which I never knew was a maintenance item at least on anything not exotic. I know they go bad when exposed to the moisture in the air from the system being empty and letting it get inside but I was under the impression that as long as the system is well pressurized the moisture shouldn't ever make its way in but there's likely more to it than that.
