The state of California likely approves a wide variety of valves for water. If you could find them that small, the best ones would be ball valves with Teflon seats. The common gate valves tend to leak. Might not be too bad if you seldom open and close them and readjust the stem packing if it needs it. Be vary careful with a globe valve, they may have rubber washers that will not stand gasoline. If the valve is labeled WOG (water, oil, gas), it may be OK.
I am disappointed on how little used ball valves are. I like the quarter turn convenience and the stems are much less likely to leak. Gate valves have been obsolete for most applications for at least 25 years. Still, you go to Lowes, etc., that is mostly what they stock. Most plumbers continue to buy what daddy did and haul it to the job in a truck with a Fram filter.
