Dino (conventional) adheres to the gears better than synthetic.
Based upon what? Any factual information to share to substantiate this statement?
Yes. Group I and II oil has better polarity. Group III, which majority of "synthetics" are today, has poor polarity for metal cling as compared to Grp I and II. Known fact and common knowledge on here.
How does that equate to less wear or longer oil life?
You mean, which is likely to wear faster, rusty initially unlubricated gears or shiny oily gears?
Ooo...let me think. Can I get back to you on that in say, 0.001 seconds?
Probably mosly significant where there is a lot of downtime, as for the farm equipment above, or my car.
I've also seen it said of engine oils in light aircraft, which spend a lot of time parked.
Longer oil life is likely to be a secondary effect. If the gears suffer more wear, the oil will have more metal in it so its likely to become less effective even though its chemical and physical properties are probably largely unchanged (though there can also be some slight catalysis of oil oxidation in the presence of metals.)
