Originally Posted By: randomhero439
Originally Posted By: NewC6
2005 Nissan Murano, 4 QT's Pennzoil Platinum 5w30
7809 miles or 10 months
I think what you're doing is pretty cool
2011 Kia Optima SX
M1 0W-40 SN
also same car but PP 5w30 SN
M1 0w-40: 7963 miles or 10 months
PP 5w30: 6486 or 8 months div>
Thanks!
Looks alright IMO, maybe a little high for my engine. Experiencing fuel dilution in my GDI and its a power-dense 4 cyl turbo so i'd be hesitate to go 8k on M1 0w-40. I noticed you commented on a supercharged/turbo factor later on to a few owners, did you apply this to mine? If not what would my new numbers be?
heres my last UOA:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2775341
Also based on my fuelly records average speed is ~36 mph, not sure if you account for that to determine severe/normal..
I did notice shortly after i gave you a recommendation that my factor was a little on the high side for some engines, and a little low for others. So i decided to take a middle ground with it. With the new factor i get 7277 miles or 9 months. However with the direct injection engines causing dilution issues, i could use a lower number in the factor and get 6321 miles or 8 months.
The UOA was good aside from the oil shearing to a 30 grade. TBN looked nice for a DI Turbo. The car is specified for 5w-40 or 5-30 correct? So even though it has sheared a bit, its still within the specified grade. Ill make a note of this case on my spreadsheet. Ill give a range for a DI engine from now on.
Thanks looks better now IMO. Would be curious how the "new way" works out on some other DI owners.
