I drive a 2003 Vw Golf. They have low tension piston rings and are known to burn a little oil.
Factory turns a blind eye to this unless consumption gets worse than 1 Litre per 1000 kms.
Mine was nowhere near this but I still had to check and top up a couple of times, between oil changes.
Since break, in the vehicle has exclusively used Mobil 1, 0w-40.
As the temp never gets colder than 32°F, I decided to switch to Delvac 1, 5w-40. Since changing 500 kilometres ago, no oil has been used at all.
Motor feels exactly the same.
