Originally Posted By: DuckRyder
Changing this filter reminds me why I detest the “SureGrip”. This filter is sort of up in a hole you can get your hand on it pretty easily, but exerting any actual force is another story entirely.
Try not tightening it so much.
Most folks over-tighten their filters - - You’d be really surprised to see how loose they can get and still not leak.
I don’t over tighten filters. Particularly this one because the fact you can’t exert any real force on it works both ways... I never tighten filters over the factory spec.
Changing this filter reminds me why I detest the “SureGrip”. This filter is sort of up in a hole you can get your hand on it pretty easily, but exerting any actual force is another story entirely. It would be very very easy to change if you could get the cap wrench on it, but you can’t because of the SureGrip. It is pretty tight to get any sort of strap or plier type oil filter wrench up there (again getting it to grab the filter is one thing, actually turning it is quite another) which is why the filter is a bit mangled. I wish FPS were easier to get.
FRAM seems pretty fully committed to the SureGrip, but I wish they would stop. Clearly with the “PRO series” they have realized it may not be desirable and I would think that an ever increasing number of vehicles have access issues.
Agree ~ when you don’t have a wide open space that coating can work against you. Worse for me is the Fusion Hybrid ~ in fact I just bought it the K&N for the 1” nut feature
I ran a TRD filter on this one that had the nut and it did work. A cap wrench makes quick work of an OE filter. I do think I remember some discussion about a cap wrench that would work on these, guess I need to go looking before next time.
Originally Posted By: blupupher
Originally Posted By: mcwilly
Does that XG8A have the same size gasket? That would be a lifetime filter on the echo!
No, from the Fram site:
XG4967- 2.118/2.438
XG8- 2.422/2.797
The inner diameter of the XG8 is right at the outer diameter of the XG4967.
It is possible they could interchange, depending on the size of the mount on the vehicle (and enough space for the filter). Bypass is close (12 PSI on the XG8, 14 PSI on the XG4967).
That was one of my concerns with the Sureggrip (fitting my filter endcap wrench) and it works just fine with mine (PH2 size, a 93/15 fits fine).
___________________________
1994 Honda VT1100: Peak 15w-40, Fram TG Filter, 3k OCI
2002 Ford F150: Havoline HM 5w-20, Ecogard Filter, 5k OCI
2012 Scion xB: QSUD 0w-20 syn, CQ Blue (Wix) Filter, 5k OCI
I’ll have to look into if there is one that will work, the one I have that fits standard filter will not work and all of the others were too large.
Originally Posted By: goodtimes
Every Fram I have seen has very sharp inlet holes, usually with small burs. Just don't understand the rose colored glasses. It's a product made by a company, what it is, it is. They have different geometry that avoids cutting the adbv, although some have impressions of the holes in them. The 4967 has a wide land for the adbv to seal on, others models don’t, like the 3614. IMHO
Are they sharp, I guess you could say that, but they are orders of magnitude less sharp than I have seen on vendor M+H (P). Yes they sometimes leave impressions on the ADBV on other models, but if you look at the tapping plate closely on those models you will see evidence of deburring at the area of contact on Fram.
The other thing easily seen here are the nubs on the end cap. All the oil flow has to go in that narrow gap the nubs provide. I would say that is more restrictive looking than inlet holes, just by eye. But it's surely calculated by the company, like the inlet holes. No one talks about the small gap for oil flow though on these filters.
I just don’t see that as a valid concern, sorry...
UOA is back:
Mobil1 5W-30 EP, 4999mi, 2007 Prius Touring, 89816
Looks really good. I bought the same year prius new and daughter now has it. I have been using the 4386 size, easier to reach. Since new , it has about 73K now she drives a lot, it has never had anyone else change the oil except me. I don't jack it up, have managed to do every change on flat ground laying on a piece of cardboard. I have a TG 4386 on it now. I do have one of these xg4367 left, maybe I’ll put it on.
You should give the XG a whirl. I can change the oil on this one without raising it off the ground with a regular filter and a longer filter would make it easier...
I just drive it up on ramps though - NBD there.
This thing has had a surprising number of recalls on it though...
I guess I have to say it is a decent car, but it certainly lacks any real qualities to endear it to a “car guy”.
Anyway.
I do have some more filter pictures I will try to put up.
I have so many filters lined up for the Prius. An XG4967 is on the waiting line. It's from 2012 so it's time. I used mainly the Japanese Toyota filters, and Thai Toyota filters with a mix of others. Never could tell the difference as to the running. One thing I notice is the oil can be just warm even after a long drive. That's why I stick to the 5k. My daughter says she likes nothing about the Prius except it is a car rather than no car. I liked it. The only recall was the pedals and inverter pump on mine.
Now I have a 2014 Volt, and finally am getting to like it.
