Hermann
Site Donor 2023
Sometimes Stupid happens.Only if somebody does something stupid.
This has been discussed here previously. I thought that was established fact.
It doesn't. You and your car would get older regardless of your membership here.The older I get and the older my car becomes, the more often I change the oil. I’m sure being a member of this forum has nothing to do with it.
Good point.I guess in theory this would also be a reason with trying to stay with one brand. Keep chemistry the same. No idea if makes a difference.
I'm a firm believer that engine noise has little to no relevance to wear. The polymers used as VIIs in engine oils have natural sound and vibration dampening properties, some more so than others. The base oils have varying sound dampening properties. This can affect how one oil will make an engine "noisy" compared to another. It doesn't mean anything has suddenly changed. The noise is always there. It's why Lucas Oil Stabilizer, which is nothing but a viscous polymer with no additives in it, will quiet a noisy engine because you're essentially coating your engine with sound deadening material. The noise is still there, any faulty part is still eating itself, you just can't hear it now. If you can't hear it, it doesn't exist.... right?
Changing the oil too often wastes natural resources and money
Among the worst 3-word expressions on the planet.I dont care.
Interesting, I saw that some put bushings in the freezer to make them easier to press in....Among the worst 3-word expressions on the planet.
small JOKE TIME:
If your oil filter is not of 'base side up' design and desire to pre-fill it you can.......
Fill the filter as high as you like then pop it in a freezer overnight. The resulting thickening will give you enough time to spin it on.
Add the rest of the oil to the pan.
Wait 24 hours for the cold oil to reach ambient temperature (in either Celsius or Fahrenheit). before starting.
The freezer is a small help but liquid nitrogen is much better.Interesting, I saw that some put bushings in the freezer to make them easier to press in....
My wife's car has, among other niceities, a digital oil pressure gauge function. Before starting one morning I toggled to get the oil pressure reading. The moment the engine turned over, it shot to @ 85 psi. After about a minute, it had settled into the 40 psi range. At 85 psi, I doubt there was much of a chance for any harm to occur.Oil pumps move a tremendous volume of oil very quickly. Cartridge filters that can't be pre-filled wouldn't exist if the motor wasn't building oil pressure almost instantaneously. Please try not to worry about it.
Unbelievable and selfish.Great, but I dont care.
I try to use the same reasonable quality oil repeatedly and from time to time I use oil with declared good cleaning abilities for a shorter OCI. Most of recent oils declare that they keep the engine clean, while only a few declare cleaning abilities. Ravenol has above-average descriptions that enable it to differentiate among its oils. The amount of information is a reason I like their oils. And their prices are acceptable here. E.g. was using Ravenol SSO 0w-30 as it meets my needs and I do not expect any significant cleaning abilities from this oil. On the other hand, Ravenol DXG 5w-30 declares ability to clean by having good amount of Group V base oil therefore after 60 000 km on SSO I will use DXG for once.Good point.
It's funny I always felt if I change the brand frequently, I may spread their weaknesses or strength more evenly. Meaning they cover each other and it would be more beneficial in a long run. Whereas if I used exact same oil every time, I may end up with a more disparity, e.g. cleaner this but dirtier that, more wear here but less wear there ...
Just subconsciously and no science behind it (that I am aware of) and I don't act on it. However, the ways sales and prices go, it's been happening!
The single expression that sums up the human race as a whole to the rest of the planet.Great, but I dont care.
