I was considering Rotella T6 5w-40, but I was concerned it might damage my cats and cause overheating.I've run 5w-40 in mine most of its life. Even a couple runs of 15w-40. Mostly 10k OCI. At 295k mine uses no oil.
How much oil is your engine burning? If the oil isn’t getting up the converter it’s not going to damage it. The one time I saw a CEL for converter efficiency due to oil consumption the vehicle was burning somewhat in excess of 1 quart per 500 miles.I was considering Rotella T6 5w-40, but I was concerned it might damage my cats and cause overheating.
It's about a quart every 1000 miles. I've heard the Zinc in the diesel oils can be bad for your cats. Granted mine is original so idk how much it's still doing anyway,How much oil is your engine burning? If the oil isn’t getting up the converter it’s not going to damage it. The one time I saw a CEL for converter efficiency due to oil consumption the vehicle was burning somewhat in excess of 1 quart per 500 miles.
Or are you concerned that an oil with a 5W winter rating is “too thin”? If that’s the case then that’s not how it works.
It’s the phosphorus in ZDDP not the zinc. But it has to get there first.It's about a quart every 1000 miles. I've heard the Zinc in the diesel oils can be bad for your cats. Granted mine is original so idk how much it's still doing anyway,
The only Toyota I’ve had that didn’t burn copious amounts of oil was my old 98 3RZ Tacoma with 160k miles, but the frame was rotting. I’m guessing it must be the guides in this one since the compression is good and the PCV was just replaced.I've had two 5VZ's and neither burned any oil, literally nothing over a 6K OCI. Something is wrong, the PCV, stuck rings or worn guides.
The PCV was recently replaced. By a ring soak, you mean Marvel Mystery Oil?10w-40 could not have possibly damaged it. I think you should change the pcv and maybe try a ring soak.
Previous owner said he changed it according to posts. People can say lots of things to make a sale. PCV's are normally not expensive and pretty easy to change.The PCV was recently replaced. By a ring soak, you mean Marvel Mystery Oil?
Thanks for posting that link and for taking the time to set the point where the relevant discussion started. I like LSjr and believe he's worth listening to.Apparently some engines will burn more oil when using a thicker grade, because the oil control rings can't handle the oil volume if the oil is too thick. Here's a video from Lake Speed Jr discussing this. The context of the video is modern cylinder coatings that help retain oil on the cylinder wall, which may not apply to your old Toyota, but if you've got clogged up oil control rings (a known issue with some Toyotas), it may be that they will work better with a thinner grade of oil, resulting in less blowby. The only way to know is to document your oil consumption with your current oil and then with a thinner grade.
Berryman's B12 another popular optionThe PCV was recently replaced. By a ring soak, you mean Marvel Mystery Oil?
