Emanuel
Originally Posted By: PeterPolyol
Having no thermostat is bad news. It not only regulates flow to the rad but when it opens, it closes the bypass circuit. No thermostat means the bypass is fully open along with the radiator and so coolant flow is unpredictable. Find a tstat asap, even a used one if you have to...
I will look for a tstat, but I had to remove the heater core recently, I put a hose between the heater core ports in the engine, shouldn´t this eliminate any problems with the bypass flow?
