Originally Posted By: Linctex
Originally Posted By: zeng
PYB 10W30 specs :
CCS @-25*C cP 6,200 (limit 7,000)
MRV @-30*C cP 23,000 (limit 60,000)
Don't worry about oil pumping.
Leave it there.
There you go!
Hard to argue with facts.
Just to add to the conversation...here's the 1975 J300 W grading system.
Note that all the grades were tested at 0F, and it was simply viscosity...if the oil gelled at -25C, the test didn't show it at all, it was just inferred that it would do better colder.
A modern 10W is tested at -30C for pumpability (limit 60,000CP, which translates to about 15,000 at -20C which is MORE than a 20W of the day was allowed to have.
If you had to start at -30C in the 1975 J300 world, you had a dice roll as to whether your oil, 5W, 10W, or 20W would do the job.
The modern tests have a MUCH higher allowable viscosity...but are tested at actual temperatures for the grade, not one temperature and cross your fingers.
Just sometimes in these discussions people think that we are comparing apples and apples when discussing "W" grades.
