Collinite 845/M26
Cali
What would be the best to layer over. Gonna wax the the Regal GS, 845 first and then M26 or M26 first and then 845, gonna give 24 hrs between layers or am I over thinking this. :D
What are you trying to achieve? All of this assumes the paint is clean and corrected before applying the wax. Claybar, Polish?
845 is great for long lasting and looks really good as well.
When I really get after my car, its Wash, touch-up scratches/chips. clay, rinse, Meguiars ultimate compound with a soft foam pad (harbor freight blue), alcohol wipe to remove the oils from MUC. Then Wax.
Shines like a diamond in a goats ...
The 845 makes it smooth as silk, excellent beading of water and shines like a mirror. I use it on my super duty.
Paint is in Xcellent condition just looking for good UV protection from HOT triple digit heat beating down on the paint. ;)
I agree with what most of the others said, Malo. Use the 845. It's quick and easy.
Also too, slap a coat on the horizontal surfaces after every wash. Takes just 5 minutes. Sometimes I don't even wait to let it fully haze over.
Scott
The only layering I've seen that does something is if you lay down a polymer sealant (Klasse SG, Zaino, etc) but dont like the hard shine it leaves. Then you can coat with a pure carnuba like P21s or Harley Davidson S100 to give it that wet"er" look.
The wettest look I got was with old school M7 show car glaze. it was wet because it was so full of oils. wicked into all of the scratches and made them dissapear. very temporary though. might as well spray mazolla on it.
Scott
Went with the 845 and put away the M26, Scott I have been using BeadMaker as a drying agent, works great for drying and leaves an awesome shine and protection. ;)
Thanks, Malo, I'll check it out. As an aside, our beloved black Honda Element has been relegated to outdoor parking. 4 cars and only 3 indoor spaces to park. I've found that nothing provides much protection, but I tried CarPro Reload on it recently. That stuff seems more durable than most. Not the killer gloss of 845 but it seems to offer really good protection from the heat and dust. FWIW.
Scott
You're using the wrong product in that case. You should be using a synthetic paint sealant like Power Lock Plus (ideally a ceramic coating). All wax is highly susceptible to heat and while there may be something left over that you're seeing, odds are it's only a small portion of the wax or just the bead maker left after exposure to hot sun like that.
