I'll bet that got your attention!
The Amish around here say that running this, or "White Gas" makes the engine run better and cleaner in applications where the engine runs slightly higher than an idle. My engine is used on a water pump, for a drip irrigation system, and is run at lower rpms. I tried this once and the engine did run good on it. Exaust smelled different. 2 days later the tank was empty,bone dry, it had 3/4 of a tank when I shut it off. I figure it all evaporated out. I refilled with regular gas, and never had the problem with missing gas again.
[ October 22, 2003, 10:47 AM: Message edited by: Pick ]
