3.8 is a good, smooth motor. It's not overbuilt, seems I recall the bottom end does not do well with forced induction. Chromoly plating on pistons, variable length intake (at least on L-cars)... we had the 3.3 version and it was great.
Timing belt, I believe on the 3.8.
THE INNARDS ON THE TRANNY are more interesting. The AT is based on the automatic transaxles in the minivans, neons, which is also adapted to the longitudinal FWD L cars. All use same innards. These are all descendants of the notorious A604, tho greatly improved. Ignore claims of "lifetime fluid." Change regularly.
Good info at "allpar.com"
