I went fishing on Thursday and left before sunrise. All the trailer lights were working perfectly. When I turned them on for the trip home the marker lights didn't come on. The stop/turn still worked and thankfully it was a short drive so I made it home without a ticket or an accident. I tested the truck the next day and the trailer circuit was dead, but fortunately it had popped a fuse rather than fry something expensive. It took a bit of searching to find the fuse but that fixed it. I was smart enough to text the trailer and find the short before just plugging it in again.
The trailer is a Bear brand made in 2006. It turns out that they did the wiring by just torching a hole in the steel tubing wherever a wire enters or exits the frame. The edges of all those holes are exactly as ragged as you would expect torch cuts to be. Between 19 years of weather deteriorating the insulation and the mechanical rubbing where the wires entered the frame there were two places with exposed wires causing dead shorts. Honestly as bad as the wear was I'm amazed they hadn't failed long before. So I spent my afternoon yesterday completely rewiring my boat trailer. I elected to run the wires along the outside rather than through the frame so I hopefully wouldn't have the same issue again. I know it doesn't look as clean but I don't really care about looks on a boat trailer LOL.
Everybody checks if their trailer lights function before going on a long trip, but how often do you really look at the wiring? It might save you a big headache to check any entry or exit points for insulation failure, and maybe even give the wires a wrap of electrical tape at those points.
