After 5 years in the deepest recesses of my 3-car garage, it's time to get the little fishing boat back on the water. Today's plan was to get a spare wheel/tire, check the lights, and run the engine for a bit.
I lucked out with a great local tire shop, who had a take-off wheel.
I did NOT luck out with the trailer lights. Last time I used the boat, I rewired the hitch connector, and put new taillights on. Every thing worked great.
Today-no light at all. I checked resistance on the trailer, and things looked good, with single-digit resistances. Then I spent an hour freeing up a lightbulb that had corroded itself into the socket. Both bulbs' filaments looked good, and resistance was futile... I mean almost non-existent.
OK-so it's got to be on the car side... Well, maybe I better put a battery on the trailer connector, first. And, we have success! By that I mean the lights worked. GRRRReat! NOT. VOM on the car connector showed 5ish volts on running lights, and 40! on flashers... I don't know what those wiring connector boxes do, but that seemed quite strange. I spray-cleaned both connectors, and when that didn't work, I used a diamond fingernail file and appropriately sized drill to clean both connectors. No dice!
I next pulled every fuse (cabin and engine) to check them out. Good news, they were all fine. OK, the harness box must be bad. The wiring exited under the spare tire well, so I backed the CX-5 onto ramps, and traced the wiring to a hole, sealed with silicone... Time to pull the back panels off the hatch. I found the harness box, took a pic, looked online for a new one, and then realized that it was past 5pm, and Mazda doesn't have parts open on Saturday. I looked over the T-clip? connectors that were installed when I bought the car, couldn't see much, but I decided to rotate them on the wires, in case I could knock off any corrosion.
Much to my surprise, this worked. After my fishing trip, I'll be back at that wiring, to t-connect/wrap them correctly. Any one have suggestions on a good tape (other than Scotch Super 33, which I already have?
