I went with the Super Start Extreme from Oreilly. a East Penn.
After advice here I decided to get a power pack with 12V cigarette accessory and a OBD2 memory saver. Just in case. I worry way too much! Plus I can carry the pack when we travel.
It works great. I hooked it up to the OBD2 connector. Popped the hood, removed the negative post first. Then wrapped it in cloth as a precaution. Next the positive post and hold down.
Removed old OEM battery then cleaned the battery cables with a brush.
Installed the new battery, put positive on first. Then the negative.
Then I disconnected the life support, everything saved!!!
Started right up with no issues.
