Originally Posted By: StevieC
Then what units do? The primary market of these units is OTR diesel applications like Doug's. In his usage, obviously this was never an issue and his usage profile is what I would describe as typical. Saying it happens doesn't provide supporting evidence of it actually occurring nor does it support that with proof of failure as a result of the claim. Doug's experience does however aptly illustrate the polar opposite. Any unit that actually successfully removed important additives from the lubricant would dramatically accelerate failure, a scenario which in turn would be widely discussed. I've seen no such discussion, have you?
Sediment in oil containers also doesn't prove anything. How many consumers do you think bother to shake their oil to get that stuff back into the mix and into their engines? Exactly. And do we even know what that material is? I believe Molakule touched on it at one point but I don't recall the exact details other than it wasn't important.
I'm not sure... From what I gather is was a bunch of units they could find while doing research to customize a design and there were before/after/control lab UOA's conducted.
That's not much to go on bud
Here's a thread with commentary from Doug in 2009
Where he states:
Originally Posted By: Doug Hillary
Hi,
Charlie - I have had extensive experience with centrifuge oil cleaners over the last 50 years or so. Maintained well they are the best type of engine oil filtration. Not all are built the same however!
I was able to do without FF filters in my heavy trucks using 35micron SS FF inserts instead. This gave almost full lubrication system oil flow when cold
I used the MANN-Hummel FM060 (previously Federal-Mogul "Spinner 2") on my engines - cleaned at every second OC (they hold 600g of contaminants) they were troublefree at well over 2m kms. There must be enough pump volume to handle these devices and in my case there was and it was avery cost effective marriage
When combined with a top line synthetic lubricant I believe that they saved interim valve bridge adjustments which in the end became a 1m kms task or as needed instead of every 200k kms
And yet another thread where Doug comments
Hi,
Joe I have had millions of kms experience with these wonderful centrifuge seperators
I have them retrofitted by Detroit at purchase to every new 500hp Detroit Diesel Series 60 engines I have purchased since 1998
This co-incided with commencing total use of Delvac 1 5w-40
They have enabled 100kkms OCIs and we now use cleanable SS 25micron mesh FF with them Previously I used Donaldson's excellent ELF FF filters which we changed at 100k - they were always completely empty after the centrifuge was fitted
I use the FM060 model which needs air to forceably return oil to the sump. The centrifuge holds about 600g of contaminant and takes about 10minutes to clean. If the paper insert is used the contaminants are very easily removed and disposed of. The capacity enables cleaning at every second OC in my fleet
Good oil flow is needed and the drain needs to be vertical in fall. The drain can be above or below the oil line but I always come in above
As they are audible in operation the driver can always tell if they are functioning. We have never had any problems and have never replaced a single part in seven years. They are able to be "recycled" to new vehicles
I believe that general engine wear has been reduced,the engines are cleaner because of the centrifuge. And by using a high quality synthetic 5w-40 HDEO of course
MANN-Hummel (Germany) are now the owners of the Spinner centrifuge name have purchased it from Federal Mogul some years ago
Centrifuge seperators have been fitted to many Euro engines over the years and are now being "encouraged" by Euro engine makers as part of extending OCIs with synthetic oils
They are a truely great product and much better than any by-pass filter IMHO
Check for my UOAs in the diesel section - "Detroit Diesel....."
Doug
From the same thread:
Hi,
the MANN-Hummel centrifuge units are routinely installed on marine engines of up to 10,000hp
MAN-B&W, MTU-Detroit, Ssangyong, Wartsila are but some. These engines may have an oil capacity of 1500litres+ - the larger centrifuge units hold up to 6ltrs of dirt
It is important that the 10c paper insert is used on the wall of the centrifuge rotor cover and then the contaminants take a few seconds to remove - no digging!
I have used cartridge type by-pass filters on a variety of earthmoving equipment (dozers, scrapers, loaders etc.) and trucks - since the 1960s!. They were once common as a xtra spec option and installed externally alongside the hood on bonneted trucks. I do not know of a truck Manufacturer selling in OZ that offers them as an option now. The centrifuge seperator is a very different animal indeed
I would not start a new heavy diesel engine in any application without a centrifuge being installed first
For those wishing to use a TP or cartridge by-pass filter - great. This thread was however concentrated on the oil centrifuge - which incidently has been around for about 70 years!
Ralph - you said;
"I have a testimonial letter from a trucking company in Queensland with over a million K on a Detroit engine with no oil drains using depth filters."
Really!!!
I do not plan to commence a "...mine is best..." or "I'll show you mine if you show me yours" debate. For me I pay the bills and sign the capital cheques - if it does not pass the cost effectiveness/whole of life test it does not get purchased!
Many commercial equipment owners do not do this and that is why they still use mineral oils and the other "easy" technology that they feel comfortable with
I have however learnt to become very reticent about claims and testimonials.
An oft sold one of the classics in the heavy truck Industry is saying "...you get better fuel economy with XXX oil over YYY oil" Really????
Another is tyre brand and wear!
Unless facts and figures can be produced such claims can be quickly discounted - the variables usually overwhelm the "facts"
XS650 - the centrifuge model I use spins at up to 6000rpm
Doug [Cheers!]
