This is my first ever UOA. I did order the Dyson Analysis. The only bolded numbers were the flash point. Make up oil was 1/4 quart and was with Castrol Syntec 5W20 that I had in the trunk (I forgot to put that it was topped off with 5W20 in the report). Makeup oil was after a long 180 mile drive at 75-85mph back from Phoenix in January (around 3K). Speed limit is 75mph if you were wondering. There were about five similar runs 70-75mph on this OCI. Infrequent short trips. Usual trip is 12 miles into work. Car is used for work and can have 24 to 150 mile a day runs. For example, todays milage was 87 miles in toto.
I will be doing further particle counts as finances permit. Current oil in the sump is GC M02/M03 mix. New STP air filter. Baldwin B-233 (oversized) oil filter. Planned OCI is around 5K for particle count consistency.
The report from Terry is pending. Being an oil analysis neophyte I don't have a clue what could cause the low flash point. Thanks for any input. Otherwise...it looks good to me.code:
Date 3/22/2006
Lab Blackstone
***Vehicle ID***
Make Chevrolet
Model Prizm
Year 2000
Engine 1.8L 4-cyl (1ZZFE)
Miles on Vehicle 108196
***Oil Identification***
Oil Brand Castrol
Oil Series Syntec GC Lot M02xxx
Oil SAE J300 0W30
API SX SL
Miles on Oil 4786
Months In Service four
***Elements***
Aluminum 1 (3)
Chromium 0 (1)
Iron 6 (8)
Copper 1 (2)
Lead 1 (1)
Tin 0 (1)
Molybdenum 5 (41)
Nickel 0 (0)
Manganese 1 (1)
Silver 0 (0)
Titanium 0 (0)
Potassium 0 (0)
Boron 1 (1)
Silicon 10 (11)
Sodium 1 (4)
Calcium 2959 (2303)
Magnesium 129 (50)
Phosporus 715 (728)
Zinc 860 (853)
Barium 0 (0)
***Viscosity***
SUS @ 210 F 62.7 (58-65)
***Misc***
Flashpoint 375 (>385)
Fuel % 0.5 (
Antifreeze % 0 (0)
Water % 0 (
Insolubles % 0.2 (
TBN 3.2
***Filters Used***
Air Filter Brand STP (has about 30K)
Oil Filter Brand K&N HP-1003
***Particle Count***
ISO Code 17/14
>2 micron 2146
>5 micron 795
>10 micron 220
>15 micron 85
>25 micron 20
>50 micron 1
>100 micron 0
