The length of the trip should not matter. If the cooling system is operating properly, it is irrelevant if you do 100km or 1000km at once, the temperature should not climb.
Also, 50/50 mix is the proffered mixture rate, as the radiator pressure cap rating was chosen by the manufacturer with the 50/50 mix in mind. If you put more water than coolant, the boiling point will increase, unless a higher pressure cap is used.
