How does a by pass filter work? I guess it filters oil that has by passed the filter but how?
Notice only www.bypassfilter.com and the Amsoil Dealers listed here: http://www.bobistheoilguy.com/orderpageamsoil.htmquote:
Originally posted by Mykro:
Here.. Check out these sites for Bypass info
http://www.garynorth
http://www.lubetrak
http://www.gulfcoastfilter
http://www.bypassfilter
http://www.wefilterit
Also do a search on this site in the oil filter forum on member # 265 (Ralph P Wood)
Read all of his posts..He is the true expert on Bypass filters.. Also go to his website listed above...www.bypassfilter.com
you can feel the filter if it's hot oil is running through it. You can also install an oil pressure guage on the the output line and see if you have pressure. That is how you would know.quote:
Originally posted by KW:
How would it know if the oil had been by passed? I'm not trying to be silly, but just trying to figure it out.
I think what he was thinking is that a bypass filter filters oil that bypassed the full flow filter due to the pressure differential. I think.quote:
The oil in a bypass filter bypasses the engine's lubrication system. It goes from the oil pump, through the bypass filter, and back to the oil sump. This works very well to completely clean maybe 5-10% of the oil pump's output and soon cleans the complete oil charge. The remaining 90-95% of the oil pump's output goes through the regular full-flow filter and into the engine to lubricate it.quote:
OK.. I understand.. I've got 3 Frantz's on my PSDquote:
Originally posted by mangusta1969:
Mykro,
I think the Frantz adapters that you referred to with the urls only have a single connection, to provide a one way feed from the engine to the bypass filter.
I think Dan's question was whether a standard oil cooler sandwich adapter (one outlet port, one inlet port) can be used efficiently with a remote bypass filter.
His concern (and mine) is whether the bypass filter can work effectively when feeding the filtered oil back to the return port of a two port sandwich adapter instead of draining into a no pressure area in the oil pan or a valve cover. The return port of dual port sandwich adapter will see almost the same pressure as the feed line from the engine.
Only the small pressure differential, typically just a few psi, that exists across the input to output side of the full flow filter will be seen by the bypass filter as it tries to return oil to the engine.
Originally posted by 59 Vetteman:
[QB] Mykro,
On your transmission why did you use an inline adapter for your trans filter? Could you not have used the 1/8"NPT plug in the test port and returned to the pan, using a standard Frantz instead of the Trans. Frantz?
Also are you running a Trans Temp guage? And if so what are your temps pulling a load up a hill? Just curious, as I am about to install a Bypass on my 4R100 using the test port and the pan return with a restricted outlet. I know alot of questions, but curiousity got me.
Here is the picture of the trans adaptor from Frantz that came with my Filter.
https://vs01.tvsecure.com/~vs01037/orders/show05.html
I Don't have a Trans temp gauge installed..
This adaptor goes on the Trans return line. It restricts the flow to the Frantz and then returns the fluid back to the Trans return line.There is always flow to the transmission since the Frantz is installed as a bypass. I've had it on my truck for six months and it works great! The truck shifts smoother since the installation. The installation was a snap.. Easy!
[ December 04, 2003, 10:57 AM: Message edited by: Mykro ]
