I recently took off and cleaned a 20 year old carburetor on a 10.5 hp Briggs engine. It was very dirty and I thought I had done a good job but after putting it back on it appears the float/needle mechanism is not working properly to stop the flow of gas. Instead of purchasing the parts and trying to fix, which I admit might be as simple as replacing the valve and valve seat, I just went ahead and ordered a new carburetor for it. I didn't mind spending the extra money, so that is not really an issue.
My problem is that when it arrived, the fuel nozzle that the fuel line attaches to is pointing in the wrong direction 180 degrees. This is not my carburetor in the picture, but it illustrates the situation. I need the fuel nozzle to be turned the opposite direction. Can I take a pair of pliars and try to gently turn the platic part around? Any other ideas? I don't want to run the fuel line past the carburetor and try to reverse the direction of it back into the nozzle.
