Originally Posted By: BrocLuno
Originally Posted By: stower17
Changing the oil now isnt going to stop the metal shavings from reappearing, it'll stop when the engine breaks in. The filter will capture the metal. Any oil in the sump hasnt been filtered yet... i bet that oil is plenty good once it goes thru the filter i bet it looks like new. Magic!
There's a problem with this thinking - not all oil goes through a filter. Yeah, sure it will eventually, but cylinders, piston skirts and cams are all lubed by "sling oil" and windage from the crankshaft. The sling oil may be filtered, but any windage oil thrown up is just what's laying in the pan .. It can throw metal up to embed in the piston skirts.
In addition, metal particles have to go through the oil pump to get to the filter. That's hard on the pump ...
IF I see little metal bits on the dip stick (it could have been slightly magnetized during forming...), I'd change the oil right now! I'd install a new filter (what if it has a tear internally...), and I'd install a magnetic drain plug. This could be a confluence of things ...
Then I'd watch all this again and see what happens?
Oil's cheap, motors not so much. And even if it is covered under warranty eventually, why go there when you may not have to? It will be time consuming if nothing else ...
What happens if you install a new filter that has a hole in it? Youre worse off then just leaving it alone because the parts continue shedding a lot until the engine is broken in. What happens if you do an oil change during break in and the fresh oil youre pouring in happens to dislodge a sliver of metal and it lands in a bearing. Id rather let oil pressure flow the contaminants away rather then a flood of oil wash everything everywhere. Also the thought of starting a new engine after an oil change when the parts havent worn in together and it takes a few seconds to build pressure... ouch.
Just my opinion to leave the FF in.
