Man, I've had a heckuva a day today trying to purge the air out of my Corolla's cooling system after changing the thermostat. It has no bleeder valve. Normally I fill the system to within a few inches of the top of the radiator, start the engine, turn the heater on, and wait until the thermostat opens, then top off the system, shut the engine off, let it cool, and top it off. Today, before I could get to it, the whole [censored] thing overflowed with scolding coolant blowing out everywhere. That's never happened before. I let it cool, cleaned everything up, topped it off, and went for a drive. No heat. GREAT. So I let it cool off again, started the engine with the rad cap off, topped it off to within an inch of being full and as soon as it started to overflow, I stuck the cap on. By that point, I still had no heat and the thermostat still wasn't open. I finally got the air bubble out of the heater core and went for a longer drive to get the stat to open and am waiting for it to cool off again so I can top it off.
How do you guys normally bleed the cooling system when there is no bleeder valve? The Stant Superstat I installed has no joggle valve like the OEM style thermostats. Do any of you guys drill a tiny hole in the thermostat so air can get past it when you refill the system? I think that was the problem today.
