I found this 2010 thread regarding bleeding brakes systems with ABS: https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2012292
That thread stated that you don't need to bleed the ABS system unless you worked on it, and to simply bleed the base brake system normally. Some people said that the ABS system fluid will mingle with the new fluid eventually. Some recommended activating the ABS system numerous times with a test drive, then re-bleed the base system again.
Is this still the recommended procedures? Any other advice??
Thanks!
Thanks!
