Best way to rotate two Coopers and two Yokohamas on Honda Accord
Dallas, TX
I own a 2017 Honda Accord with Coopers (50k warranty) on the rear at 7/32" tread and Yokohama Avid Ascend GT (65k warranty) on the front at 11/32" tread.
I would like all four tires to wear out at roughly the same time, if possible.
Since the front tires tend to wear more quickly on front wheel drive cars, would it be wise to leave the Yokohamas on the front and rotate them side to side every 7,500 miles and do the same with the Coopers on the rear?
Yes, keep the fronts (with more tread) on until the tread evens out. I don't think there's really any reason to swap side to side as long as they aren't wearing uneven between sides, which they shouldn't if your alignment is in spec.
Just start your rotations when you see about equal tread on each tire.
If it were mine, id leave the yokos on the front until they wear to 5/32, then switch them to the rear. when the coopers wear to 5/32 swap again.
