Originally Posted By: mechanicx
I meant less messy than a dome down filter as far as getting oil on you. On the engine, it might be a different story
My Vette has the dome down setup ... typical small block Chevy. Trick there is to unscrew it enough to let the oil drain down the sides of the filter, and let it drain until it's done ... then remove it. Or wear some rubber gloves.
