Originally Posted By: Gokhan
Originally Posted By: ChrisD46
I believe for a GDI engine you would want as low a NOACK oil as possible to keep intake valve deposits at bay (along with top tier gas , shorter OCI's , etc.) with a GDI engine.
Nope, on the contrary, the lower the NOACK and/or higher the base-oil viscosity, the more the intake-valve deposits will be. Alternatively, the higher the NOACK and/or lower the base-oil viscosity, the less the intake-valve deposits will be.
This is because one mechanism of cleaning of the intake-valve deposits is evaporation. If NOACK volatility is low or the base-oil is thick, the oil will spend more time on the valves as it evaporates more slowly, therefore leaving more deposits behind.
Intake-valve and combustion-chamber depo...ts their growth
So, if you want the least intake-valve deposits in a GDI engine, you need to pick up a 0W-20 with higher NOACK. A 10W-30, which has both a thick base oil and low NOACK would be the worst choice as far as the intake-valve deposits are concerned.
From the article: "The most important lubricating-oil component for deposit formation is the base oil. Increasing the high molecular weight (high viscosity) and low volatility content of the oil increases deposit formation."
Question: this study comes from Europe. I am wondering if they don’t have the emission controls like we have in the States which aggravate this condition? Also they have had better gasoline than we get. I keep reading how higher octane gasoline is better for higher compression GDI engines.
