Here's a new video about it:
I'm not at all sure that's true. The battery energy density has not appreciably changed since the first 18650 was introduced in 1994. Discounting the cheap Chinese cells, all modern cells are made to a specification. With AH, lifespan, charge rate and power output taken into consideration. There is no magic here.At least for private cars battery technology seems to be moving too fast to lock into specific packaging and related standards for long enough to make the concept pay off. Tesla and Ford using the battery housing as a structural component might be an obstacle as well.
Might be practical for heavy vehicles or fleets like taxis.
Plus, bigger pack brings less charge cycle, more life span of the vehicle.Well, I can only go on what I read in the news and we never know what's around the corner even if lithium-ion technology is plateauing. It seems all new EVs have considerably more range than older ones, even if it is at the expense of additional weight. Increasing ranges avoids the cost and inconvenience for many owners of using public charging and I'm personally finding that's a huge benefit even though I've realised I actually enjoy the ritual of charging.
Swappable batteries or power units have been talked about for two decades. Use standard interfaces and form factors, and then be able to exchange either slurries (for flow batteries), battery units, fuel cell stacks, hydrogen tanks, whatever.
A big issue is that an 18650 cell is virtually worthless by itself, and so long as every battery looks different and meets different interfaces, let alone control approaches, it’s hard to get some commonality.
Depending upon how harnesses and other things are done, BMS can stay with the battery or higher level controls. Quite often there are master/slave blards, and the BMS will have to interact with other higher level control systems, so those lines of demarcation can and do move.The BMS will need to be part of the pack and be swapped, along with some cooling system as most reliable pack are liquid cooled. Also the "labor" factor in swapping since it is usually not a DIY, even if a robot does it you still need to dedicate space and equipment cost (an inventory of batteries, robot, exterior like fences and tent if not a building, charging infrastructure). My gut feeling is you will need to spend more swapping than charging in a parking lot slowly (parking lot is something you need anyways).
What works in China for these swapping is the car company partner with the battery company, the car company then sell you the car without the battery and you subscribe the battery with limited number of swap per month, with charges included. The cost of the battery subscription with the charge inside is about the cost of typical gasoline on the gasoline car, and the EV prices without the battery becomes close to the gasoline car prices. This is not something easy for US to follow because 1) we have cheap gas, compare to the rest of the world, like 1/3 to 1/2 of the rest of the world prices, 2) our upper middle class (target EV buyers) are not driving limited range inside the urban center like in China where they live in the big cities and don't drive 200 miles a day, 3) we do not tax our gasoline car to way more than normal sales tax and then gave EV tax incentive that is near tax free (our car price is almost half of most of the world where they tax like 100% of sales price). 4) Their government wants to get away from oil import for geopolitical reason, whereas our government owns the oil industries and the oceans for moving them around the world, with no concern for oil energy security.
Even if we (US, Europe) have battery swap standardized I suspect it will be the supplement battery and we will have much shorter range, that we can DIY and plug into the trunk connector, that we will only swap for long road trips. We will likely still have a main battery attached to the bottom of the car as our day to day primary battery.
You’re mistaking cell design parameters such as coat weight and electrode thickness, with the actual energy density of the powders that intercalate Li. Separators have also gotten better and thus thinner.From Sony's initial production run of 18650's, Lithium batteries have been capable of as much as the 250 watt hour per KG range, remember, they are not always configured for this much energy density. The 18650's range of 2500 MAH to 3600 MAH is somewhat weight dependent (heavier batteries have more capacity) , internal configuration dependent (more wraps have more capacity) and discharge/charge rate dependent. Although we are led to believe there have been "major" advances, that's not as true as it at first seems. What has happened is that the cells have been refined to be safe, to have long life, and are now well configured for the intended use. That's no small matter for the end user, as the cells are now quite reliable!
Look at your Lithium powered tools for a good example. 4AH, 5AH and 6AH battery packs remain about the same size as they have always been. We do not have 6AH Dewalt battery packs that are the size of the old 2AH packs.
Of course they may. Thinner or different electrodes and tabbing will make a difference in the mass of the cells, as will protective devices. Not to mention the basics like can wall thickness, electrolyte composition and loading, etc.Chinese cells weigh less, often considerably. Its not just the electrode. Nor did you address my point of specific energy or energy density.
BYD and Nio did ok with them, of course the business model and geographic is different as I mentioned above.Battery swapping is simply nothing more than a fantasy in today's EV's. Does nobody remember the ill fated Better Place battery swapping startup company that went bust in 5 years after much fanfare? I could see if you're making a video hyping the idea how it would be convenient to just skip over that fact. Car manufactures (Tesla included) have absolutely no incentive to standardized anything or to make batteries swap-able unless the government mandates it or it saves them money and at this point neither is going to happen in the near future.
BMW battery packs use the A/C system for cooling. Not going to swap that very quick. Be faster to charge the battery with a hamster in a wheel.The BMS will need to be part of the pack and be swapped, along with some cooling system as most reliable pack are liquid cooled. Also the "labor" factor in swapping since it is usually not a DIY, even if a robot does it you still need to dedicate space and equipment cost (an inventory of batteries, robot, exterior like fences and tent if not a building, charging infrastructure). My gut feeling is you will need to spend more swapping than charging in a parking lot slowly (parking lot is something you need anyways).
Interesting....Much bigger condenser? Good idea really, as its a fair bit cooler than a regular coolant style system.BMW battery packs use the A/C system for cooling. Not going to swap that very quick. Be faster to charge the battery with a hamster in a wheel.
