quote:
Originally posted by Terry:
Deluxe,
I have never said wax or any other crystals are in Auto-RX or desirable in that or any formulation.
Just the opposite. Nor is cloud point a germain issue or relevant. Note that the bio based source of the esters do limit the pour point of the Auto-Rx product and that like all bio based products thickening at cooler temps is an issue, likewise the color and texture of the product are dark and thick unlike any petroleum based product you may have seen using ASTM D 2500. We did not find separation of the formula an issue at any temperature. Nor does the product affect the host oil or vice a versa.
Auto-RX is not a lubricating oil but an ester based cleaner that has shown EP/FM modifying characteristics.
I believe some uninformed observers are misinterpreting the room temp gelatinus structures of certain esters in Auto-RX as solids or wax which in my opinion is incorrect.
My encapsulating theories are based on disbursing using a polar micel at a micronic/ angstrom level not an object that would be visible without a microscope or other amplification tool.
The esters in Auto-RX have nothing to do with any kind of crystal that I am aware of. I have observed others, including your comments above, mention this but I have not seen it in my testing. Nor have I ever purported that assertion.
I repeat there are no solids that I have seen in Auto-Rx that contribute to its cleaning or lubrication capability. The tolerances between the piston rings and cylinder wall would be much too restrictive to allow a 40 or 50um particle of "wax" to be very effective or uniform enough to perform in that high temp/high pressure environment were Auto-RX functions flawlessly.
My comments about supersyn stand. Unless the esters in that product are enhanced and or increased they are in my opinion lacking in high performance applications. I believe they are not for cost reasons.
To substantiate that assertion, consider the recent last minute addition of Moly after the "unmolyed" versions showed poor EP performance.
I do agree that additional testing and possible reformulation of Auto-RX would be required to be used in place of Mr.Jackson's Supersyn esters.
Seems to me you have read or heard second hand opinions of these issues which I have also heard but have never agreed to based on first hand analysis interpretation.
Thanks for bringing this up as others may have held the same misconception about my point of view.
