Originally Posted By: cronk
Originally Posted By: PontiacFan
Originally Posted By: bmwtechguy
While I like Auto-rx and have used and still use it with very good success, there are limits to what it can do. It must have flow to do any good, and when the gravity flow STOPS on these drainback holes, Auto-Rx cannot clean them out.
If this is true, then where are the DISCLAIMERS on the auto-rx site.
Give me a break! You need a disclaimer to say it needs to circulate through the engine to work?
Do you also need a disclaimer on your knifes to tell you they are sharp, or your stove to tell you its hot?
I guess you need some level of common sense to use Auto RX.
I did a search since I'm new here, and it seems auto-rx has less than a stellar record. A friend gave me a bottle, it sat in my trunk, and I went out the next morning when I was about to pour it into my engine, and guess what, the auto-rx was not even pouring out, this is not a product I want in my engine, I decided to go and buy a quart of MMO and the next morning and it poured right into my engine. Both morning's the temperatures were about the same.
I know alot of members like auto-rx, but I am glad I learned how to use the search function and gather some information, but I will be giving back the auto-rx to my friend since it does not shake in the bottle, you would think that a product like auto-rx would pour better than regular motor oil, but that is not the case, I will see what MMO does, and I then can always try Kreen.
