MolaKule
Staff member
Suggested concentration or not, I would NOT use it in an MT or an AT because it has the potential to upset the static and dynamic friction coefficients of the formulated fluid.
sw99 said:...Fear mongering is common every where. I have really ran into it in a major way as I have been walking my premature death rate backwards for the past three years. I have my improved health and lab work numbers that support my case.
Below is a fact sheet that I am now following for Archoil AR9100 usage...
You really need to look at the definition of Fearmongers:
This can take the form of psychological manipulation that uses fear-based tactics (scare tactics) including exaggeration and usually repetition to influence the public in order to achieve a desired outcome.
So far I haven't seen any of this.
What I have seen are people trying to explain lubrication principles, technology and chemistries, and why any external chemistry may not be compatible with the internals of a specific piece of machinery.
Advertising FAQS and hype are not necessarily FACTS.
A dedicated MTL or ATF has a specific friction modifier chemistry to affect the dynamic friction coefficients in a transmission, and any external chemistry may be antagonistic to or compete with that formulated fluid.
One can choose to ignore the technical facts at his own peril.
Molakule why did you see fit to quote me in this post? Were you not in the similar niche once upon a time as Archoil is still today?
