Originally Posted By: Gebo
Originally Posted By: BigD1
Straight from the Toyota pdf I linked earlier.
Remove, inspect, and clean pad clips
to ensure a smooth open/close
operation when the brake is applied,
and replace if damaged
DO NOT apply any grease or
lubricants to pad clips when reinstalling
I apologize for not seeing your PDF. I was reading so many responses that I just had "glazed" over. All I have are Toyota's. I am printing the PDF now. Thank you, sir. Well, this explains why I got the little packs of black grease with my Toyota pads. It also explains why the rear pads (never changed) have black grease here and there as well.
Not a problem.
Just pointing out that Toyota is recommending the pad clips be installed dry, and to me that means no grease under the clips, and no grease on the pad ears. If grease is used on the pad ears, the ears sit in the clips, so that would be, in my opinion, just like using grease on the clips.
If it were mine, I would install shiny new clips, and just take a wire brush, and clean the area where the pad clips sit in the caliper bracket. Then use some brake cleaner to de-grease the area.
Not a problem.
