Originally Posted by ZeeOSix
Originally Posted by Sayjac
GM has said no combo valve in their ACDelco oem ecores, they use standard poppet type dome bypass.
They must not be very confident in the combo valve operation.
That would be my take. This much certain, unlike the separate poppet type bypass used now in the for GM ACDelco, a combo valve is the cheapest design available and thus only seen on lower/lowest tier of filters. Also true, when GM spec'd ecores before like the OP's anecdote, because of block bypass no combo valve. So for GM at least, a combo valve is a no go in their ACDelcos for GM. And even now stipulated, a separate poppet type bypass more "consistent" and thus more reliable and accurate for bypass psi by design.
As mentioned many times this subforum, a nitrile adbv can and does lose pliability over time and with temperture change. When bypass function is part of that, much more critical than just controlling some oil drain back.
Back to topic, as noted in the OP's case the ST and ACDelco construction are the same. Would not be the case for newer GM vehicles where ACD has a separate poppet type bypass, ST equivalent would use the cheaper combo valve.
